All,
I have a Schlage Touchscreen Deadbolt hooked up to my Vera Lite and everything is working quite well (only had it for about a week though)
The lock has 3 built in alarm options; 1)chirps if the door is opened/closed, 2) tamper alert if someone messes with the lock and 3) Forced Entry alarm.
The problem with the lock is that you can only enable one at a time so what I’d like to do is to enable option 1 when we’re at home and option 2 or 3 when were out.
Thats where I need some help. The parameters are configured over here: Contact us | Schlage Door Locks Customer Support and I’m able to set those through the device options configuration settings on the lock itself but I dont know how to configure it from a script perspective so I can set different values based on different conditions. I looked at PLEG but cant find the option of setting but it doesnt seem possible to set those options from there. Is my only option Luup code and if so can someone point me in the right direction?
Thanks!
