set scene to only able to execute at certain times?
I have scenes that send alerts to a wall mount tablets via Imperihome. But it’s been waking the baby up during nap times. I want to set it so that it only send the notification at certain time of day. Where do I go to set this?
You can control when scenes can run using Lua code. See Conditional Scene Execution for an explanation and example code.
I do not know if the above solved your problem, OP.
But when I went to resolve this issue, suchas turning a night light on when I come home at night but not during the day, I setup another scene that only enables and disables the primary scene from functioning. Hope this helps.
This is where “PLEG” plugin comes into play. Stock scenes are very limited and you quickly hit a wall were you want more but it’s just not gonna work. Then you move to PLEG.
