I am quite new with PLEG and I could certainly use some help. I have the following:
Amy Garage Door Opens
Jeff Garage Door Opens
Yamaha Receiver
Main Kitchen Light
Main Hallway Light
Schedule One hour before Sunset to 22:30
I want the Main Kitchen Light ant the Main Hallway Light to go on during the time schedule if the Yamaha Receiver is off and Amy Garage Door or Jeff Garage Door Opens before the Kitchen Door
The receiver off tells me no one is watching Television. If I don’t have the Garage door open prior to the Kitchen Door then the lights go on if we leave in the evening.
Aaron,
You can’t put an expression as as argument to a sequence expression. An expression does NOT have a timestamp. Only inputs and conditions have timestamps.
The second approach should work.
But if you leave garage doors open … you will want to set the REPEATS on the GarageDoors condition so that it gets a new timestamp when any door opens, even if the other one is already open.
[quote=“RichardTSchaefer, post:3, topic:183711”]Aaron,
But if you leave garage doors open … you will want to set the REPEATS on the GarageDoors condition so that it gets a new timestamp when any door opens, even if the other one is already open.[/quote]
I thought you might not be able to thank you for confirming.
How do I set REPEATS? Sorry I am really quite new at this. I have read hours of discussions on these boards but it is a lot to consume until you actually dive in and use it
How do I set REPEATS? Sorry I am really quite new at this. I have read hours of discussions on these boards but it is a lot to consume until you actually dive in and use it[/quote]
So now I have a different issue and not exactly sure what I have done wrong. When we enter the house and tYamaha_Switch is false lights come on perfect. Later in the evening we turn those switches off manually. We then turn the Yamaha receiver on to watch TV. When we turn off the Yamaha the lights come back on. Any ideas ? Thanks
[quote=“jquincy, post:10, topic:183711”]So actually today it went this way.
sKitchenHall in time slot
tAmyGarage opened
tKitchenDoor opened
Kitchen Main on
Main Floor Hallway on
Now I turned off Kitchen Main and Main Floor Hallway
I just turned on tYamaha_Switch and then turned it off after 5 minuter
Kitchen Main and Main Floor Hallway both come back on[/quote]
Sometimes when I need to find the problems (since I’m not always smart enough to find the problem by looking at it in a whole) I break it down into test sections. So make 3 test conditions with no actions just to see when or which one is staying true when it shouldn’t be.
Yes you can see your problem right there.
cTest3: (cGarageDoors;tKitchenDoor) Is true because the garage Door was opened then the Kitchen door was opened.
cGarageDoors were opened at 2014-11-06 18:46:17.502
then
tKitchenDoor was tripped at 2014-11-06 18:46:25.907
So you need to rethink how you attack this. Sounds like you want this to be true only when you first come in for the day but not again until?
You can solve this a few different ways. If above is true only the first time after the garage doors are open, you can base it off time and when the door was opened like this.
(cGarageDoors; Now > 5:00) If you add that to this " Schedule AND !YamahaReceiver AND (GarageDoors;KitchenDoor) AND (cGarageDoors; Now > 5:00)"
Now the whole thing will only be true for 5 min after one of the garage doors was opened. After 5 min. they would never auto come on again until the door was reopened.
You can also add another order to it, so like if or once the receiver was turned on after doors were opened or closed it would be void until the door opened again first before the receiver.
Thank you very much for helping me through this. I was stuck on this. I will try this tonight. I thought through this but wasn’t exactly sure how to execute it.
So all was good for a good while and now I have an issue. I have added various things to my PLEG and now I have the issue I had before. Once cMain,cMain2 and cMain3 three are true when the kitchen door is opened the lights go on. Would appreciate any suggestions.
Looks like your PDF file is missing a all of the conditions.
Check your conditions that use schedules. Many of your schedules do not have an OFF time.
This means your schedule is always true … and maybe your conditions are always true.
In that case you will need the REPEATS set to re-trigger.
I should have looked at it after I ran it through the scanner. Sorry about that. This has everything in it except the last page of actions. It is over the 512kb. I appreciate your time
