I would like to control the level of one on-site sewage facility. By control I mean receive a notification if a certain tank level has been reached so I can take the necessary precautions.
Is there any zwave device that I can use? Would a Fortrez WWA-02EU work? :
Or am I being a bit lunatic? ;D
Thanks again!
What about an Everspring ST812-2 Z-Wave Water / Flood Sensor?
@Guessed wrote a plugin for a relay board with analog inputs. At the bottom of the tank install a Stainless Steel Pressure Transducer (0-5PSI) with a 1-5 Volts DC output and feed into one of the analog inputs…the rest is pretty easy. The transducers can be pricy ($125) but work well with sewage. We do something similar on our yachts.
If you use a control by web analog module it will really siimplify things and send you notifications without having to code the Vera.
Regards
Tim Alls
AllSeas Yachts
