I am rather inexperienced with home automation and programming - but am keen to do the following and hoping someone can help me. I think it’s actually quite simple request so am thinking someone here would know straight away!
I want to send a UDP command from my Vera. I am running AltUI and think I need to enter Lup code (but have no idea how to do that). I think the Lup code needs to be in a scene?
The UDP command would be sent to my LightwaveRF WiFi link and be a command to turn lights on / off.
An example UDP command would be :
111,!R1D1F0
I need to send this to IP address 10.0.1.147 (on the same subnet as the Vera box) on port 9760
I have tried and tried but can’t work out how to do it,
Sorry this isn’t an actual reply to your question but have you considered getting a RFXtrx433E device? I use one of these with my Vera Edge and (in conjunction with a free plugin) it allows my LightwaveRF devices to appear and be controlled just like my z-wave kit (but without polling/response). The ability to integrate my LightwaveRF stuff was one of the main reasons I went for the Vera. Oh, and the RFXtrx433E also allows me to get readings from my Oregon Scientific temperature/humidity sensors and my Owl energy logger. All with no programming required!
Yes, UDP is very simple and would require a bit of code which probably would go into a scene. It goes something like this
local ip, port = "127.0.0.1", 2003 -- change these to what IP and PORT you need
local message = "whatever message you like"
local socket = require "socket"
sock, msg = socket.udp()
if sock then
sock:setpeername(ip, port) end -- connect to destination
sock:send(message)
sock: close()
Those are the basics. Of course, it could be much improved if properly tailored to your specific needs.
Richard - good idea, but I was hoping to avoid spending more ? on hardware if I can get my WifiLink to work
Akbooer - thanks. I only posted this in the AltUI forum as I couldn’t see where to put the code in the standard Vera UI. Is there somewhere to do it without AltUI?
