I want to send formatted emails from Vera 3 to myself. I would make up a daily status report, about those things that didn’t need immediate action, then send it once per day. How can I do this?
I’ve used the Email Notification plugin (SMTP Notification, from Massalia) which is great, but whatever I try to do, simple text formatting doesn’t work. I’ve tried using Luup coding to build up a string variable, with newline breaks, then send it using the SMTP Notification plugin. The newline breaks get stripped out and it’s just one long string of words. I suspect that its not the plugin stripping the newline characters out, but I’m not sure.
I also tried manually creating an http-formatted message in a text editor, then sending that through the plugin. It came out on Outlook as a plain text message, showing all the http code.
Does anyone know how to do what I want - I’d be happy with just newline breaks. Http would be better, but not essential.
Thanks,
Pete
