Sending Config Settings Via Luup
For the past couple of days, I have been playing with sending my Remotec ZTS 110 config settings to parameters 6 and 7 (Upper and Lower Limit Set Points). I finally had some success tonight by dissecting the zwave logs and various other posts on this forum from years ago but the settings will no longer set the parameter, working off the same line of code that worked only minutes ago. Configuring these set points through the Vera Device Options works well, however I am creating a UI and would like to change these settings without using Vera’s UI.
When controling the device through the Vera I see in the log that it completely restores the whole thermostat but the actual send line for parameter 6 would be
41 07/23/14 19:24:22.829 0x1 0x11 0x0 0x19 0x7 0x6 0x70 0x4 0x6 0x2 0x3 0x20 0x5 0x0 0x0 0x0 0x0 0xc 0xac (######p#### #######) <0x2b637680>
Device Properties
Device # 11
Altid 7
Parameter 6
ZTS 110 is on batteries and I fear wakeup of the device might be affecting this.
I have tried two different command styles.
Lua
I got this working for a few minutes
luup.call_action( ‘urn:micasaverde-com:serviceId:ZWaveNetwork1’, ‘SendData’, {Data=“0-x19-7-0x6-0x70-0x4-0x6-0x2-0x3-750”}, 1 )
log output
41 07/23/14 21:35:57.065 0x1 0xb 0x0 0x19 0x7 0x6 0x70 0x4 0x6 0x2 0x3 0xee 0x71 (######p#####q) <0x2b9c1680>
42 07/23/14 21:35:57.107 0x6 0x1 0x4 0x1 0x19 0x1 0xe2 (#######) <0x2bdc1680>
42 07/23/14 21:35:57.107 got ACK – not expected send: (nil) exp -1 got -1 <0x2bdc1680>
41 07/23/14 21:35:57.107 ACK: 0x6 (#) <0x2bdc1680>
42 07/23/14 21:35:58.252 0x1 0x5 0x0 0x19 0xc 0x0 0xef (#######) <0x2bdc1680>
41 07/23/14 21:35:58.253 ACK: 0x6 (#) <0x2bdc1680>
Http
Could not get working and from the log it seems to be sending to device # 15
http://192.168.1.13:49451/data_request?id=lu_action&DeviceNum=1&serviceId=urn:micasaverde-com:serviceId:ZWaveNetwork1&action=SendData&Node=7&Data=x70-x6-x1-800
41 07/23/14 21:35:31.610 0x1 0xf 0x0 0x19 0x7 0x4 0x70 0x6 0x1 0x20 0x5 0x0 0x0 0x0 0x0 0x26 0x9e (######p## #####&#) <0x2b9c1680>
42 07/23/14 21:35:31.642 0x6 0x1 0x4 0x1 0x19 0x1 0xe2 (#######) <0x2bdc1680>
42 07/23/14 21:35:31.643 got expected ACK <0x2bdc1680>
41 07/23/14 21:35:31.643 ACK: 0x6 (#) <0x2bdc1680>
42 07/23/14 21:35:32.802 0x1 0x5 0x0 0x19 0x26 0x0 0xc5 (####&##) <0x2bdc1680>
41 07/23/14 21:35:32.802 ACK: 0x6 (#) <0x2bdc1680>
Any help would be appreciated. I am very new to this so I have tried my best at research with no luck. Thank you in advance.
