Send user that unlocked schlage lock via Vera Alerts
Hi All,
Did quite a bit of searching, and only found partial information.
I’d like to send a pushover alert via Vera Alerts, for when a user unlocks a schlage deadbolt. I have configured to send an alert using * for all users, however the notification does not specify which user it was that unlocked the door, only that the door has been unlocked.
What Luup code will I need to do this?
Appreciate it!
-Newbie!
If you want to look at using VeraAlertTemplates … but that’s a bit complicated.
The easiest way is to create a separate notification on your lock for each user code.
Then you can have a separate message for each user.
[quote=“RichardTSchaefer, post:2, topic:178330”]The easiest way is to create a separate notification on your lock for each user code.
Then you can have a separate message for each user.[/quote]
+1 This is what I am doing.
It is set for different PIN codes I want to monitor, and that then sends a message via VeraAlerts
What is your VeraAlerts code look like?
I’ve tried this and it is not sending the door user ID # being used…
OPEN Front Door Lock {device([172].service[urn:upnp-org:serviceId:VSwitch1].Status) | Choose(0={tone:3},1={tone:1})}{Device([139].Lock.sl_UserCode) | String.LockUserName()}
thanks for the help!
Can Anyone help?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
