Send a zwave contact event to Vera Controller
I intend to use a “GBGS 1000 Uers RFID Reader & Keypad Door Access” unit as a card, tag or PIN unit to control a Vera based security system. I wish to use the keypad’s NC, NO output to switch the system “home” or “away”. I need to direct the units output to a device which can “zwave” to the Vera controller. I intended to use the contacts in a door/window sensor to accomplish this. Can anyone recommend a unit to do this that is known to work with a Vera unit? Thanks…
It’s always best to indicate what part of the world you are in as there are different product requirements.
I don’t think that I have heard of any door/window sensors that do not work with Vera. In the U.S. the following sensors are all known to work well and accept external inputs.
Schlage RS100HC Door and Window Sensor
Aeon Labs Aeotec Z-Wave Door/Window Sensor, 2nd Edition (DSB29-ZWUS)
Fibaro Z-Wave Door/Window Sensor
