While studying how to best link the Aeon Labs Aeotec Multi-sensor with a Vera 3 I’ve encountered contradictory instructions. Vera’s doc page re this sensor says to bring it to the Vera for inclusion. Elsewhere I read that you should install the sensor in its destination location, have it powered by the method it will remain in (USB or battery), and bring the Vera to it for inclusion. I believe the issue users are dealing with is that the sensor needs to know its neighboring z-wave devices to ensure proper communication with the Vera. To add to my confusion there are references online to “the overnight heal” – like it’s a common installation step, which I can only assume is because the sensor wasn’t included properly. Any comments about how to properly include it (move sensor to Vera or move Vera to sensor for inclusion, “overnight heal”, etc.)!?
My goal with the sensor is to have it detect motion in the driveway. Upon detection I want it to turn on a light if it’s dark outside. This seems like an obvious application but I can’t find docs that describe how to do it with the Aeotec sensor and a Vera. Instead, I’ve found a tutorial at Vesternet that describes how to do this with a different sensor and there they recommend having the sensor talk directly to the light switch instead of going through the Vera. Another Vesternet tutorial describes using the Aeotec sensor to control a scene, which seems to contradict their assertion that direct association is better. Mainly, though, the latter tutorial doesn’t deal with having the trigger be conditioned on the sensor’s illumination detection. More confusion. Has anyone seen docs that deal with my specific application (motion sensor detects motion which triggers switch on only if sensor says it’s also dark outside)?
Thank you.
