I am curious as to what got him blocked and for how long. His messages are very helpful to those struggling with their setups.
Mcv doesnāt even know this forum (really the old one) is their biggest asset. #listentoyourusers
A thousand year ban? That sounds excessive.
This is the opposite of good management.
Do not blame Sorin! He is a true patriot and had no hand in this.
He is the forum manager, who else could do that?
People higher in the organization.
I donāt think it was Sorin that banned him, so maybe best to give him the benefit of the doubt?
C
Heās currently blocked for 1000 years (roughly) I understand. For breaking forum rules
C
I think we as a community all must be told why he was banned. This way he cannot even defend himself. Does he even know himself why he is?
The reason has been stated. He broke forum rulesā¦
C
How did he do that? What rule dit het broke with and where? (Trying to learn what no to say when being too honest)
Sorry chap. Youāll have to ask those that banned him. I am simply repeating the ācorporateā lineā¦
C
But who banned him? Thats what I ask for few posts up.
Iām not prepared to answer that, chap. I have some ideas, but no facts. Draw your own conclusions
C
Click on the user id of a poster (or a reply with the @user in a gray bubble) and you should get a pop up of the user, showing their status. For @rafele77 you will see a banned duration until April 3020 and a reason of spam.
FYI - rafale77 is very active on the Home Assistant Community forum and his code is hosted on Github (Z-Way OpenLuup plugin, Vera-extroot) - all under his same handle.
Observation: the last commenter in this topic has been banned, as was the originator of the topic.
But on to the subject at handā¦ I have spent a couple of days doing my own work at separating one of my Veras from the mother ship. Iāve solved a few problems that rafale77 apparently had not. All remote access, remote provisioning, etc. have been stopped. I have confirmed over the last 24 hours that the only traffic that remains is Veraās fetch of the current weather, which may not be worth the trouble to drill out (failure of the query has no effect on system stability), but I might do it anyway just because Iām ornery that way.
I have reduced the procedure to scripts, one to decouple, one to recouple (itās entirely reversible almost instantly). I am still doing QA, particularly on the hardening aspects (e.g. making sure it reboots reliably and quickly with no delays, time is stable, longevity testing, etc.). If that continues to go well, Iāll publish the scripts later this week for the experimentation of the bravest of others. Since I donāt have a Secure, Iāll need a volunteer to work with on that platform, preferably someone fluent with WireShark or proficient enough with their own firewall to set up filter rules with logging for traffic tracing. PM me if youāre such a person.
Iām interested in testing this, when available.
Iāve removed the Alexa skill in favor of ha-bridge, so, apart the convenience of using the app, Iām ok to completely remove the cloud part from my system.
OK. Here it is. Tested on my Edge and Plus. All the usual caveats apply:
- The author is the worst tester. Although it works on my two systems, I still regard my validation as a single data point, and you know the value of one data point in extrapolating a conclusion.
- The process does things that are counter to the design of the system, and you assume all risks.
- Read the README completely before doing anything. Understand what youāre getting into.
- It is not tested on Secure, because I donāt have one.
- Forgot to mention: itās undo-able without a factory reset.
Please use the Issues section of the Github repository to ask questions or report issues. I will use this forum thread for infrequent announcements on this topic only. I believe there is a non-zero risk of any of us being banned for discussion in this thread (two already have fallen, as I noted earlier).
Other comments:
- CLARIFICATION: This decoupling process does not prevent your Vera from using any plugins or code that uses cloud services or other remote APIs, and these will continue to work. This process only removes the āinvasiveā Vera/eZLO cloud system-dependencies that seem to cause fragility in our systems, make unsolicited changes to them, etc. It is expected, for example, that Alexa, Google Home, Nest, etc. all continue to work on a decoupled Vera system.
- This is new work; it is not a respin or update of @rafale77ās prior efforts, although it will, of course, have much in common with it. I have been able to solve some problems he had not yet solved as of his untimely banishment from these forums. I have validated the extent of its decoupling and have not found any exceptions yet (although testing has been days, not weeks or months). But I believe it is now theoretically possible to have a stable Vera that runs without Internet access at all.
- The script provides some additional functionality, including local backup of system configuration daily, local backup of rotated logs, and local syslog feed of system messages.
- The script fixes Veraās broken date/time handling on boot. It turns out that OpenWrt has an included, fairly workable approach that the Vera boot process corrupts. Veraās application of its own broken default can result in erroneously triggered scenes and other automations where date-time is a trigger, and additional reboots/reloads when time is later slewed to correct.
I also have been able to create a stable build environment for OpenWrt and packages, and have so far successfully built updated versions of many much-needed packages, including LuaSec 0.9, OpenSSL 1.1.1h, and faster JSON parsers and other handy tools. When I get through a bit more testing, I will publish a repository with documentation.
