I am fairly new to this! I’m using a Vera Plus (Firmware 1.7.4001) and I have just bought a Secure SSR 302, when I include it, it was not recognised as an SSR 302 only as a generic z-wave device.
I get a Parent device urn:schemas-upnp-org:device:Heater:1 using device file D_Heater1.xml
And two child devices urn:schemas-upnp-org:device:Heater:1 using device file D_BinaryLight1.xml
I can control the SSR 302 and it’s status gets reported (after about 5 mins) but I do not get any failsafe functions.
We do not have this device model integrated with our controllers. Our list of compatible devices can be found at: https://getvera.com/compatibility/
I suggest contacting our Customer Relations Department by sending an email to support@getvera.com and seeing how we can assist you.
Bit late probably for @ZenSlo but just bought a new Secure 302 my old one wasnt zwave plus and I wanted a backup, any when I installed it I had the same problem you need to change the settings on the two child devices
device_type - urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1
So I thought the new one was ok after I made the changes above but when running a reactor sensor the HW sometimes turns off randomly but still shows calling for heat! (The receiver does not go into failsafe mode as this could cause that problem) I have spent hours looking at the logs to see if I could uncover what was causing this but cant pinpoint anything, when I put the older model back on everything works fine…
So its going back and I have just ordered a Nest 3rd Gen, I have been reading that the Vera Plugin is broken but to be honest I dont care…all I seem to be doing at the moment is removing things from Vera, the more I remove the more stable it gets, shame I really wanted “one ring to rule them all”
Thanks @cw-kid the Thermostat has been been working ok mostly I reinstalled the old 2 channel then copied the config\settings which match yours above it then configured correctly but still had the problem random HW drop out but I guess the reply from ionut.a says it all… I just dont get why the older version is detected correctly and works, but the new zwave plus version does not, anyway game over for secure receiver and stat roll on Nest and my android phone
