I just got my Vera light and a Secure SRT321 thermostat to control my floor heating.
I succesfully synced my Secure with vera but the “set temp” stays at 0 no matter what i do with the Secure thermostat. The “room” temp is successfully transmitted to Vera.
What am i doing wrong.
I also tried the same Secure thermostat with my “Indigo” controller and the Secure thermostat works perfectly.
I believe this is a known problem with the current version of UI7 firmware so, if that is what you are using, you may need to wait for the next release for a solution.
device_file: D_Heater1.xml Wakeup interval (seconds): 256 Poll this node at most once every: 128 seconds
I use this short Wakeup interval to reduce the time it takes for the 'stats to get the setpoint changes that I send out from PLEG according to time and various state changes. It costs me more batteries but they still last several months.
