Secure/Honeywell SRT321 no feedback Vera Edge
Hello,
I am just setting up my Vera Edge, and have added relays and dimmers (both fibaro) without any issues. I am trying to add 2 x Secure thermostats but I am having difficulty.
I can connect to the Z-wave network by adding device, then getting the stat to join. But I am not getting any feedback on either stat.
I get a red banner saying waiting for wakeup to configure device. I cannot find anything wrong with what I did according to the manual, and I have used these before albeit with a Vera Lite.
Help!!!
Please send us an email to support@getvera.com regarding this issue so we can investigate further. Thank you!
i’ve he same problem.
I received an email feedback from vera support : in the next firmeware update the SRT321 compatibility will be solved.
Check out http://forum.micasaverde.com/index.php/topic,27402.msg213497.html#msg213497
I am having zero problems with two srt321 in Ui7.
Hi Jespolini,
any chance you could post your settings for the devices and a step by step of how you set it up?? I have tried following your instructions but I still have no two way control.
I have spoken to both Vera and Secure and both have left me deaf with silence :-\
I really just want my thermostats to work again!!!
The post you referred to is a step-by-step, I don`t think I can do any better…sorry.
What settings are you referring to? I can post whatever you want :slight_smile:
Did you add the SRT as a Generic Z-wave device? Have you tried to remove it from the network and start over following my post? When Vera says waiting for Wakeup, you set the SRT in LI mode, and then go to advanced → configure node now - right?
Robg1400
I am having problem with transfering data from my webbrowser to the SRT321.
Everything is working fine the other way or with imperihome.
Im the same, the Vera reads the devices but cannot send commands to it, after following the instructions above. This is incredibly frustrating.
Help anyone!!!
Could you tell me group you use to pair your devices? I had some issue with creating group number 2, so I created group with number 1.
[quote=“robg1400, post:8, topic:185445”]Im the same, the Vera reads the devices but cannot send commands to it, after following the instructions above. This is incredibly frustrating.
Help anyone!!![/quote]
What is your wakeup interval set to?
The same as yours.
I have the same 300 seconds.
Feedback is still one way, I cannot change the stat either from the web interface or the app. But both the app and web interface can see the changes i manually make to the stat. Also the heat/off buttons on the app don’t do anything.
Could you double check that you added those ModeStatus variable?
http://support.betaalbare-domotica.eu/get-setpoints-working-in-ui7/
