Second Vera
U have a Vera edge already installed and working. Would like to instal another at a different location. How to set two installations separate but having one common administrator. Can you please direct me to any link clarifies this issue ? Regards,
What issue do you have? I have 4 veras under my account and 3 are in different houses.
Thanks integlikewhoa.
When you login you will find all four controllers and can select the one you want, right ? What happens to other users. Will they see all four controllers and will they be able to connect to them. I dont want that. I have not yet registered the second Vera. Really waiting for your expert help on how to proceed. Hope yoiu got me. I want to loginto both controllers. Other users should be restricted to only one of them. Will it work that way ?
Regards, Sree
[quote=“sre, post:3, topic:189985”]Thanks integlikewhoa.
Regards, Sree[/quote]
Yes if they have a different account you can choose which vera or veras are on your account and which ones are on their account.
Thanks appreciated. Will register and return, should I have difficulties. Regards, Sree
