I just purchased the Sears Assurelink upgrade kit for my existing garage door opener. Installation was a breeze. Just replcaed the original opener pad with the assurelink one and hooked up the Assuirelink router to one of Vera’s ethernet ports. I was in business minutes after. Sears is no longer charging $20 a year for this service and the apps are free.
It looks like Assurelink works similar to Vera. You log in to the Assurelink website (either via page or app) and it checks the status of the door and allows sending a close or open command. I’m wondering if I could have Vera send those commands so I can integrate it with her.
Sears seems to be ignoring my request for any API or similar. Work has been pretty demanding and at this time I do not have access to a hardware packetsniffer I could put in front of the router to intercept traffic to it from the Sears assurelink site.
having worked 60-80 hour weeks the 1st 3 months of this year unfortunately not. Things are finally calming down but my ToDo lits is about a mile long and this is one of the lower priorities…
My ability to open/close the garage door using VERA via AssureLink has been broken since upgrading from UI6 to UI7. I did a factory reset and no longer see the app that I previously used. I’m guessing it isn’t listed b/c of an incompatibility with UI7.
The app is there, and much improved by JoeyD. Look for MyQGateway in the app store. It works on both UI5 and UI7 amd now also supports gate openers and lights. As well as being more stable.
Thanks for the info everyone. Ordered my Assurelink gateway today and looking forward to getting back to have this ability. We had a tree fall on our house and grounded power out and fried my garage door opener. I was using a relay switch before but won’t work with this craftsman opener. Glad I may have found new way to work with it.
That was super easy to install and agree with zwave-user. A lot easier to use and quicker response using via vera than iphone app or assurelink website. Again, thanks everyone for getting me going in right direction.
