I am trying to script something that will check to see if 3 lights are on or not, if not then do XXXX , if any are on then do YYYYY
The code I pulled together was as follows, but I get an error on the first line, and I can’t work out why?
[code]local LI_DEV1 = 82
local LI_DEV2 = 22
local LI_DEV3 = 42
local SEC_SERV = “urn:upnp-org:serviceId:SwitchPower1”
local HA_SERV = “urn:micasaverde-com:serviceId:HomeAutomationGateway1”
local v = local function checkLightsOnOff()
local livingroomlight = luup.variable_get(SEC_SERV, "Status",LI_DEV2)
local bedroomlight = luup.variable_get(SEC_SERV, "Status",LI_DEV1)
local halllight = luup.variable_get(SEC_SERV, "Status",LI_DEV3)
if(livingroomlight == "0")then
if(bedroomlight == "0")then
if(halllight == "0")then
luup.log(“v is " … v)
luup.call_action(HA_SERV”,“RunScene”,{SceneNum=44},0)
With my limited knowledge it would have to be something like:
local LI_DEV2 = 22
local LI_DEV3 = 42
–local v = local function checkLightsOnOff()
–luup.log("v is " … v)
luup.call_action(HA_SERV,“RunScene”,{SceneNum=“44”},0)
I’ve commented out the logging and function part, not sure about those. I think in your luup.call_action you have extra " after HA_SERV and the scenenNum is missing them “43”
Now this may well be the partially sighted, leading the blind here, but you commented out the function I was after, so i changed it to this.
local LI_DEV2 = 22
local LI_DEV3 = 42
–local v =
Shouldn’t be better to test all the lights at one time with an “AND” condition ?
Also, you created a function but you don’t call it anywhere… The function is useless here, code it directly, no ?
local LI_DEV2 = 22
local LI_DEV3 = 42
local livingroomlight = luup.variable_get(SEC_SERV, “Status”,LI_DEV2)
local bedroomlight = luup.variable_get(SEC_SERV, “Status”,LI_DEV1)
local halllight = luup.variable_get(SEC_SERV, “Status”,LI_DEV3)
if ((livingroomlight == “0”) and (bedroomlight == “0”) and (halllight == “0”)) then
luup.log(“All light are off”)
else
luup.log(“One light is on”)
luup.call_action(HA_SERV,“RunScene”,{SceneNum=“43”},0)
end[/code]
The reason I wrote it as a function was with the idea that I could do a series of group checks, such as lights on , sockets on, doors opened etc. - I’m very new to any sort of coding, so i’m still finding my feet. - so the idea was that I could do function checks, rather than check individual devices.
There is one other thing I want to do, and thats to add more ‘ifs’
Let me see if I can make that work, I’ll post my attempt here later.
I’m just using a luup.log command at the moment to test it out first, but for some reason when i run the following only logs the results of the first two ‘if’ requests, not the third?
[code]
local LI_DEV1 = 82
local LI_DEV2 = 22
local LI_DEV3 = 53
if (livingroomlight == “0”) then
luup.log(“living light is off”)
else
luup.log(“living light is on”)
if (bedroomlight == “0”) then
luup.log(“bedroom light is off”)
else
luup.log(“bedroom light is on”)
if (halllight == “0”) then
luup.log(“hall light is off”)
else
luup.log(“hall light is on”)
[quote=“parkerc, post:7, topic:173319”]OK, here’s my next hurdle…
[code]
local LI_DEV1 = 82
local LI_DEV2 = 22
local LI_DEV3 = 53
else
End
else
End
else
[/code][/quote]
I think this should work. By having the end statements after every if block you avoid them being part of the preceding else clause. Am I making sense?
local LI_DEV2 = 22
local LI_DEV3 = 53
else
else
else
end[/code]
Now I’m probably pushing my luck now, and also stepping outside my own comfort zone, but rather than logging that text to the log file. Any ideas how I can capture those same words to memory so i can refer to them again ? I would like to use them in a single Sonos ‘Say’ command?
You want to have the strings, i.e. “Living light is on” stored? Why not just invoke the SAY command from this script? Or you could declare global variables and store the status in those, or the Variable container plugin?
