This may be of use to others. I spent a couple of days getting this right.
It uses the amazing AutoRemote app to keep me updated and in control remotely. I use if for the heating system but you can easily change its use.
The easiest way to do this is open YOUR autoremote link - http://goo.gl/XXXXX and fill in a box. Then copy the code on the right. Break it down and put it in here…
Yes, I know you could just keep it all as one string… but this way I one set of LUUP code and I can reuse it without much effort…
[code]–Get Current Temps from VTemp Controller
local tUpCurrent = tonumber((luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”,223)))
tUpCurrent = tUpCurrent … “?”
local tDownCurrent = tonumber((luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”,191)))
tDownCurrent = tDownCurrent … “?”
–Controller Mode - ECO/Normal
local dn_mode = luup.variable_get(“urn:upnp-org:serviceId:HVAC_UserOperatingMode1”,“EnergyModeStatus”, 118)
local up_mode = luup.variable_get(“urn:upnp-org:serviceId:HVAC_UserOperatingMode1”,“EnergyModeStatus”, 182)
–Build HTTP String
local httpstart = “https://autoremotejoaomgcd.appspot.com/sendnotification?”
local httpkey = “key=[YOUR-KEY-HERE]”
local httptitle = “&title=Heating%20System&text=Updated%20Information”
local notice_sound = “&sound=7” --Chosen Sound File from Settings of App
local httpsoundvib = notice_sound … “&vibration=10,120,” – Vibration Pattern
local httpid = “&id=60001” --Constant ID for Notification so the same one is upadated
local httpiconled = “&icon=[YOUR-URL-OF-IMAGE]&led=yellow&ledon=150&ledoff=50” – Icon on Left and LED Colour
–Set up the buttons
–Check Downstairs to set up the right icon
local httpactions1 = “&action1=down&action1name=Dn%20-” … tDownCurrent – Concat the result for the button name
local down_status = luup.variable_get(“urn:upnp-org:serviceId:VSwitch1”,“Status”, 39)
local httpactionsicon1 = null
if (down_status == “1”) then
httpactionsicon1 = “&action1icon=presence_online” --use the built in icons
else
httpactionsicon1 = “&action1icon=presence_invisible” --use the built in icons
–Check Upstairs to set up the right icon
local httpactions2 = “&action2=up&action2name=Up%20-” … tUpCurrent – Concat the result for the button name
local up_status = luup.variable_get(“urn:upnp-org:serviceId:VSwitch1”,“Status”, 38)
local httpactionsicon2 = null
if (up_status == “1”) then
httpactionsicon2 = “&action2icon=presence_online” --use the built in icons
else
httpactionsicon2 = “&action2icon=presence_invisible” --use the built in icons
–Check Boiler to set up the right icon
local httpactions3 = “&action3=water&action3name=Water”
local boiler_status = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”,“Status”, 229)
local httpactionsicon3 = null
if (boiler_status == “1”) then
httpactionsicon3 = “&action3icon=presence_online” --use the built in icons
else
httpactionsicon3 = “&action3icon=presence_invisible” --use the built in icons
local httpsubtext = “&subtext=Down%20” … tDownCurrent … “%20-%20” … dn_mode … “%20|%20Up%20” … tUpCurrent … “%20-%20” … up_mode
local httpsender = “&sender=Vera”
local httpfinal = “&sender=Vera&persistent=2&statusbaricon=ic_action_home&ticker=Home%20System%20Update”
local httpcommand = httpstart … httpkey … httptitle … httpsoundvib … httpid … httpiconled … httpactions1 … httpactionsicon1 … httpactions2 … httpactionsicon2 … httpactions3 … httpactionsicon3 … httpsubtext … httpsender … httpfinal
luup.inet.wget(httpcommand)[/code]
