Screen never off
I just installed this app/plugin combo this week, and I love it. But:- I have some problem with it on my asus transformer prime - the screen is always on. The picture is black, but the menu bar is visible (even though I have deselected this option!), and therefore, the backlight is on.
Of course this sucks the battery fast… I have disabled the camera wake up feature, but still the screen is on.
Hmm strange thing. Did you try to follow the alternative method ? (explained here : [url=https://imperihome.zendesk.com/hc/en-us/articles/201369913]https://imperihome.zendesk.com/hc/en-us/articles/201369913[/url])
I am having the same issue with my Transformer Prime. The screen goes dark like I want it to but the backlight never goes off. My plan is to have the tablet mounted on the wall, but this is a big problem to me. The files located on the page for the alternative method do not exist so cannot try this option. Not sure where to go next with this issue.
I’ve been searching Google Play store for suitable apps to overcome this annoyance.
As I’m trying to use cheaper low-spec tablets for wall mounting, they don’t have light or proximity sensors (of which there is a plethora of apps available for waking the screen).
I have come accross the app ‘Sound Light’ (https://play.google.com/store/apps/details?id=com.amira) which wakes up the screen based on sound - specifically designed for at night time when you’re in bed and want to turn on a light without having to turn on a switch or find your phone. It gives the option of using the screen as the light (as well as the flash).
I’ve emailed the developer to ask them to add a 24/7 option as it currently forces the use of a timer with a max of 8hrs.
My testing of the app’s adjustable sensitivity found that walking past it (shoes on a hard floor) was enough to turn the screen on, but also simply tapping the screen with my fingernail generated enough noise to wake it up.
Will be very happy to get this funtioning full-time.
If you are also interested in this app as an option, please email the developer to let them know there is interest.
Thanks.
I thought i will post another intresting method here,
I also had problems with the wake up by cam feature as the screen would not completely turn the backlight off
I have the tablet mounted in the kitchen as main panel to control the alarm system, ip cams, lights etc.
I have an infrared zwave PIR mounted in the kitchen and i use that to trigger to go from standby to display and back to standby with complete dark screen.
It works like a charm using the API setpage function, for instance by using the imperihome plugin.
Only drawback… You need this sensor but i have it anyway cause i am using the PIRs to trigger vera as an alarm panel.
