Schlage Window/door sensor showing up in UI5 as a 'motion detector'
​Posted by: Z-Waver
? on: October 07, 2013, 06:51:42 pm ?
Insert Quote
Thing have changed since two years ago when this thread was started. Your Schlage sensors didn’t even exist then. Next time, start a new thread.
For your Schlage sensor go to the devices Advanced tab and change these two fields:
Device type: urn:schemas-micasaverde-com:device:DoorSensor:1
Device file: D_DoorSensor1.xml
Starting a new thread. So much for thinking of reducing clutter by reusing threads :slight_smile:
Anyway thanks for the suggestion, I tried it out, rebooted but still got the trip and no trip notification options, same as in motion sensor
SO is the DoorSensor.xml just a clone instead of implementing open/close status or do I need to update anything ?
Thanks !​
Tripped = door opened
Not tripped= door closed
[quote=“SteveZ, post:2, topic:177262”]Tripped = door opened
Not tripped= door closed[/quote]
Terrific ! Works exactly like you said Steve ! Thanks all ! Keep up the great work !
One question - in motion sensors, ‘not tripped’ = not tripped for 2 minutes right ?
For motion sensors, “not tripped” means it’s not detecting motion at the moment.
While it is true true that “not tripped” means it’s not detecting motion at the moment, at the same time it can not be detecting motion and still be “tripped”. For instance the Schlage motion sensors stay tripped until motion is not sensed for 4 minutes. I know some it’s nit-picky, but I feel it’s important to quantify that little distinction.
It’s also important to note that I believe some motion sensors only remain “tripped” while they detect motion and immediately return to “no tripped” once the motion stops. It’s important to know how your specific sensor works (i could be wrong on this last part as I only have schlage sensors).
For instance the Schlage motion sensors stay tripped until motion is not sensed for 4 minutes. I know some it’s nit-picky, but I feel it’s important to quantify that little distinction.[/quote]
Motion Reset Time factory default is four minutes. However, a five second motion reset time can be attained by placing a jumper across both pins of the TEST connector that is located inside the sensor.
Not too get off subject but can you add a name to the schlage sensors? Like front door, back door etc?
Yes, using the Device parameter name on the Advanced tab for each device.
Excellent thank you!
