Well sort of. A few posters were asking about different things that you can do/control via Z-Wave with the Schlage (Trane) thermostat and I assume the RCS as well. While I can’t go into detail, below is a list of things that I have been able to control and/or get status of.
Status Only
LCD Contrast (Numeric Value)
Internal Sensor Calibration Offset Setting (Numeric Value)
Filter Service Reminder (On/Off)
Maintenance Service Reminder (On/Off)
Recovery (Enabled/Disabled)
Controllables
Hold (On, Off - Run Mode and Off - ESM Mode)
Fan (On, Auto and Cycle)
Mode (Heat, Cool, Off and Auto)
Energy Save (Save, Normal)
Cool Set Point (Normal and ESM)
Heat Set Point (Normal and ESM)
Schedule (On and Off)
Display Lock (On and Off)
System Type (Gas/Elec. and Heatpump)
Fan Type (Gas and Elec.)
Changeover Type (w/Heat and w/Cool)
Temperature Scale (F and C)
Minimum OFF Time (Numeric Value)
Minimum RUN Time (Numeric Value)
Service Mode (On and Off)
Fan Cycler ON Time (Numeric Value)
Fan Cycler OFF Time (Numeric Value)
2nd Stage Heat (Enable and Disable)
AUX Heat (Enable and Disable)
2nd Stage Cool (Enable and Disable)
Maximum Heat Set Point (Numeric Value)
Minimum Cool Set Point (Numeric Value)
Backlight Timeout (Numeric Value)
Set Filter RUN Time (Numeric Value, will override interally tracked number)
Set Filter Servie Interval (Numeric Value)
Set Heating RUN Time (Numeric Value, will override interally tracked number)
Set Cooling RUN Time (Numeric Value, will override interally tracked number)
Set Maintenance Servie Interval (Numeric Value)
Those are all the ones that I have come across.
Enjoy!
