Schlage touchscreen deadbolt
Anyone know these new locks from schlage are compatible and easy setup with Verde.
There is another thread devoted to these locks:
http://forum.micasaverde.com/index.php/topic,13334.0.html
Bottom line is they are compatible but you need to be diligent in including them within you Vera/VeraLite. While unconfirmed at the moment they do seem to have some kinks to work out within the software as well.
Ok, I finally got it working. I ended up getting a long network cable and removing it from the micasa and then re-adding it. worked fine.
Now, the issue i have is the touchpad stops working when paired to the micasaverde. If i unpair it the touchpad starts working again. Sort of defeats the purpose if I’m outside. I can’t get in without using my phone to unlock the door. Anyone hear of this?
Look at the other thread devoted to this issue that tjoyce mentioned above. There are a few issues with these locks that are currently being investigated by Schlage/Nexia and soon Micasaverde.
