I notice that my notifications on the findvera.com website have all the info on who entered with my schlage locks and with which PIN, but is there a way to be able to do this directly with the Vera router? After I enter a PIN and unlock I immediately go back to my PC which is already telnetd to the vera and look at the /tmp/log/cmh/9-ZWave.log file which is pretty well empty all of the time and I read in another post that you could use that file to see such events locally but there is nothing in there.
In my Advanced → Logs page I have everything checked except for “Verbose logging” and “Lock Log Levels (not recommended)”
When I run my command “ps -ef” it lists the following:
PID Uid VSZ Stat Command
1 root 2360 S init
2 root SW [keventd]
3 root RWN [ksoftirqd_CPU0]
4 root SW [kswapd]
5 root SW [bdflush]
6 root SW [kupdated]
8 root SW [mtdblockd]
53 root SWN [jffs2_gcd_mtd4]
66 root 2360 S logger -s -p 6 -t
68 root 2360 S init
77 root 2484 S /sbin/syslogd -C128 -m 0
79 root 2352 S /sbin/klogd
217 root SW [khubd]
387 root 1520 S /usr/sbin/nas -P /var/run/nas.wl0.pid -H 34954 -l br-
562 root 2368 S crond -c /etc/crontabs
582 root 2380 S udhcpc -t 0 -i br-lan:0 -b -p /var/run/br-lan:0.pid -
583 nobody 1208 S /usr/sbin/dnsmasq -D -y -Z -b -E -s lan -S /lan/ -l /
584 root 1868 S /usr/sbin/dropbear -p 22
592 root 6032 S lighttpd -f /etc/lighttpd.conf
595 root 2360 S telnetd -l /bin/login
639 root 2360 S /bin/ash /usr/bin/Start_NetworkMonitor.sh
641 root 2356 S /bin/ash /usr/bin/Start_CurlQueue.sh
650 root 7308 S /usr/bin/CurlQueue
651 root 7332 S /usr/bin/NetworkMonitor
666 root 2360 S /bin/ash /usr/bin/Start_DCERouter.sh
680 root 7332 S /usr/bin/NetworkMonitor
681 root 7332 S /usr/bin/NetworkMonitor
682 root 7332 S /usr/bin/NetworkMonitor
804 root 2372 S /bin/ash /usr/bin/cmh-ra-daemon.sh
868 root 2020 S ssh -p 56861 -T -y -i /etc/cmh-ra/keys/cmh-ra-key.pri
896 root 2364 S /bin/ash /usr/bin/Start_Device.sh 9 ZWave
910 root 2364 S /bin/ash /usr/bin/Start_Device.sh 10 Generic_IP_Camer
2398 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2401 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2402 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2403 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2409 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2410 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2411 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2412 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2413 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2414 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2415 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2416 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2417 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2418 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2419 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2420 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2421 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2422 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2423 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2424 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2425 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2426 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2428 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2429 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2431 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2432 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2434 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2435 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2437 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2438 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2439 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2441 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2442 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2443 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2445 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2446 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2447 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2449 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2450 root 7544 S /usr/bin/Generic_IP_Camera_Manager -r 127.0.0.1 -d 10
2451 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2452 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2453 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2454 root 7544 S /usr/bin/Generic_IP_Camera_Manager -r 127.0.0.1 -d 10
2455 root 7544 S /usr/bin/Generic_IP_Camera_Manager -r 127.0.0.1 -d 10
2456 root 7544 S /usr/bin/Generic_IP_Camera_Manager -r 127.0.0.1 -d 10
2457 root 7544 S /usr/bin/Generic_IP_Camera_Manager -r 127.0.0.1 -d 10
2459 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2460 root 7544 S /usr/bin/Generic_IP_Camera_Manager -r 127.0.0.1 -d 10
2461 root 22676 S /usr/bin/DCERouter -l /var/log/cmh/DCERouter.log
2462 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2463 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2464 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2465 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2466 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2467 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2493 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
2495 root 9408 S /usr/bin/ZWave -r 127.0.0.1 -d 9 -l /var/log/cmh/9-ZW
21856 root 2368 S /bin/ash --login
22132 root 2364 R ps -ef
root@HomeControl:/tmp/log/cmh#
And my netstat command has alot of ESTABLISHED localhost connections as well. Dunno if this is really a problem or not.
On another side note does anyone know how I can cahnge the Timezone to central time vs the UTC that shows 6 hours ahead.
Thanks alot,
undertaker
