I’m soo stuck with this. I am trying to pair my Vera2 with my Schlage link door lock but cant for the life of me figure it out. This is how i’ve been doing it… Can anybody shed some light?
pressed the z-wave button on the back on the device and waited for the zwave light was flashing every 1 second.
typed in the program code in the schlage doorlock
pressed schlage then 0
the schlage button then flashed red 4 times.
If you can’t get it to pair, it helps to reset the lock itself. Schlage has a procedure. Do you have the deadbolt or lever lock?
I have attached the Schlage reset procedure:
DO NOT reset your lock unless you are able to locate the original programming code. Customer service cannot retrieve a lost programming code.
For FE599, disconnect the batteries. For BE369, disconnect the 9V battery. On the lock keypad, press and release the Schlage button. Reconnect the battery and wait until the Schlage button is no longer lit. Within ten (10) seconds, press and hold the Schlage button until it lights green and the lock beeps.
Funny I just order 3 of the Vera 2 and almost cancelled them today until tech support called me and said they work fine with Vera 2. The truth will be told when I get to Florida on Monday. I also bought a Schlage Link Bridge to give it a test run. It’s worth the $13 dollars a Month if it works.
It doesn’t…see my other topic. Go with the Schlage LiNK and return the vera while you still can. Tech support claimed UI4 would fix the problem so I did not return mine in the 30 days. It doesn’t.
I am ordering a Bridge and once it is set up, ebay the vera2.
Hey Shady
Did you have to use the set up process in the wiki to pair the Schlage lock. I followed that procedure when I first purchased the lock, worked like a charm (with Vera 1) With Vera 2 is this process no longer required.
[quote=“ctvrod, post:7, topic:166140”]Hey Shady
Did you have to use the set up process in the wiki to pair the Schlage lock. I followed that procedure when I first purchased the lock, worked like a charm (with Vera 1) With Vera 2 is this process no longer required.[/quote]
Judging by davidlee’s post above, you can still use the procedure with Vera 2. I don’t have Vera 2, but my guess is that it can be done through the wizard as well (at least that was MCV’s intent I believe).
I upgraded from Vera2 UI2 .996 and my schlage deadbolt was working fine before and after
the upgrade.
I am now on UI4 1047. I just added another pin and went back and verified that
it was in, vera shows it and shows the new code.
I won’t be home until Sat afternoon, but would be more than happy to test anything.
Les
[quote=“djrobx, post:3, topic:166140”]Does anyone have a Schlage working with 1.0.996? (UI2)?
It worked fine on an older revision. With this revision they pair. I can see my 4 PINs, but I cannot control the lock or add/remove codes.
I tried removing it from Z-wave and re-adding it. It re-detected my 4 PINs (so they’re clearly communicating), commands just fail.[/quote]
UI4 (1047) still does not work. You can see the attached pix show the code seems to make it, but then closing lock, and reopening shows it gone again…HELP!!! please…
Here is what the healing process produced…So to recap, have tried to get this to work with all three UI’s, excluding, resetting the lock, then repairing with each UI change. Lock seems to work fine in all other ways (can remote lock/unlock, it sends notifications, I can see PIN’s set on the lock) just will not allow me to set users/pins via software. ???
I stumbled around with the Schlage lock as well with Vera2 and 1.1.992. It ended up working perfectly once I physically un-installed the lock set and took it to the room where Vera2 is connected. Apparently, there are security protocols which must be transmitted directly between Vera2 and the Schlage with NO NODES in between. Once configured and tested, re-installing the lock set and letting it connect through the network nodes worked fine. (I had first tried to take Vera2 with the battery pack to the lock set but that did not work for me.)
That is the one angle I did not try…Do I need to unpair all my other devices and start from scratch (or turn them off) before doing this? or just unpair lock/reset it/ remove it from door/ and repair next to vera2?
Working with UI4 - Absolutely. I found that to correctly configure the lock, it needed to be in the room with Vera and using the method 1 of including devices.
After adding the lock, wait sufficient time for the security protocols to exchange then full test the lock (not yet installed in the door). After configuration, install the lock and as long as the network nodes are in range, it will take its place.
I did find that when upgrading from 1.1.992 to 1.1.1047 the lock seemed to lose its settings, however opening the device and clicking reconfigure corrected it.
I too just upgraded to vera2 and had problems adding devices.
My schlage dead bolt is the last problem. I tried taking Vera2 with the battery to the lock, no luck. I saw one of the posts said to bring the lock to Vera2. So I did! I have uninstalled the lock and it is sitting on top of vera2 and she can’t see it. I’ve reset the lock, I’ve un-encluded it and tried to add it. Vera never “flutters” to acknowledge any of these.
Any ideas?
ps. this lock was previously paired to vera1, no problem.
did you remove the lock from Vera 1 first.
You must always do a remove node before repairing or resetting that node. If you don’t the node information can still be in place in either device. This will cause problems.
What I would do is
vera 1 do a remove node from the advanced tab in the PC’s gui. Do not use the buttons on vera! Do not do a add /remove. Pick Remove
look at the screen progress you should get found node removed node.
follow the procedure with Vera 2 and if UI-4 go to add remove in the top bar of the dashboard. use add/remove device click remove one. Watch the screen look for the progress it will take about 15 min to exchange all codes
