and my Schlage lock was working fine and then after the upgrade the notifications stopped. I can still poll the node and I can try to send unlock commands which it says it works but nothing actually happens. It also shows a good green battery and the lock works fine from the keypad.
Any ideas on what happened and how to fix it? Anyone else have this happen?
I think I had this with my Kwickset locks also a while back after using the new branch etc. In the end I had to get the lock to reconfigure to fix it, and it’s never done it since.
I had this exact problem. I finally excluded, and then re-included the lock. I also added 2 GE plug-in dimmers which pick up and transmit the signal a longer distance. Works beautifully now.
It seems like the 1.1.1245 broke something in the Schlage signal (because it worked fine before the upgrade), but only for those locks that were on the edge of the signal distance. My closer lock always worked without a hitch.
[quote=“newts, post:1, topic:168513”]I upgraded to the latest:
You are running the latest version: 1.1.1245
ballroller
did you upgrade to the new Zwave firmware 3.2. if so i thought that was going to fix that type of problem. I am still using vera 1 (system info below), vera 2 waiting in the wings, the most important part of my system is the Schlage locks. For reasons that you have described is why vera 2 is resting on the shelf.
Wayne
Yes. I’m using 3.2. I had purchased the GE dimmers before the upgrade, so I don’t know if it would work without them or not. Wasn’t about to take the chance!
[quote=“ctvrod, post:4, topic:168513”]ballroller
Wayne[/quote]
