I just installed a schlage lock. It worked great while I left the VERA 3 on the floor next to it. I could add pins, get notifications, scheduled access control etc. As soon as I moved the Vera back to it normal position and did a heal, the device wouldn’t configure or would configure but had poor communications saying unable to get manufacturer. I have two GE wall switches and added one AEON repeater within 5 feet line of sight of the switch. How do I configure the route manually to go from VERA 3 to the repeater to the switch? I tried putting the repeaters ID in the manual route field of the lock in the device options tab, but that didn’t seem to do anything.
Is there anything else I can try. I can’t really move the VERA as I want to add other locks around the house.
I’m having similar issues with my lock. Works great when Vera is near it but when I move Vera to its resting place (and run a heal), I get errors such as “Failed at: Getting manufacture”.
I have several devices (all within 10-15 feet) that I assume would work as a repeater but none seems to be working).
GE, Leviton, Cooper, and Aeon.
My autoroute looks fairly sad:
12-80x,14-81x,16-81x,5-87x
I’m guessing my devices aren’t routing properly as they all have good signals/routes back to Vera.
No resolution. I just moved the Vera closer. Support offered to try setting up a manual route but I don’t have time to keep messing with it right now. It will only be an issue if I add another lock.
Does anyone know if the aeon repeater supports ZNB (“Zensor Net Beaming”)? Supposedly, the node nearest the lock needs to support ZNB (to wake up the lock).
