schlage lever lock
Was considering the purchase of schlage link lever lock FE599, and since only the schlage deadbolt BE369 is usually mentioned here and in the wiki I wanted to check first that this lock is fully supported by Vera, anyone using this?
They lock is fully supported. It even has Vera has more features for the lock than most other products. There is one thing. Vacation mode. This locks the keypad from use while on vacation. Vera does not support it yet. You should be able to do this manually though.
Thanks for the feedback!
I put one in about 3 weeks ago - works like a charm, as long as you are careful about the distance of the Vera from the lock.
