schlage lever "bad pin code" event
all my alerts/scenes with this lock seem to be working except “bad pin code”, when i enter a bad pin the lock flashed red but it does not alert me or run the scene, anyone have this working? (vera2 UI4)
I am only guessing but if I remember correctly the lock will lock you out if you enter a bad pin code 3 times in a row in so much time or something like that. Maybe the event does not fire until these conditions are met.
I am not sure if you are doing this with the lock but I thought it would be worth mentioning.
pgrover516,
Do you have a scene set up to use the bad pin &/or have notifications enabled for entry of the bad pin?
As an example, I have one scene set up with one pin code that we use when leaving the house to run the AWAY scene (notifications not enabled), another scene using seperate pins to start my HOME scene when one of us returns home (Notifications enabled) and a bad pin scene to turn on my outside lights, one inside light and archive 30 secs of video from my courtyard camera (notifications enabled ).
JOD.
yes I have a scene set up and it works when i test it manually but it doesnt trigger when I enter a bad pin, does it need three attempts as someone mentioned?
no The attemps are at the lock before the lock alarms or blinks red!
ok, so I create a scene for “bad pin code” to notify and take an action (turn on a light) i enter a bad pin, the lock flashes red but the scene does not run, the lamp does not turn on and I get no notification, if I press the “run” button for this scene on the dashboard it does run the scene, does anyone else have this “bad pin code” working correctly in a scene? Ideas?
Interesting. I had the scene in UI2 and checked now but its gone with UI4 .1086. I tried to create it again but the scene wont save.
I checked Mantis and did see a report about bad pins not working in a scene but then lost the page and cant find it again. (It’s not my day today)
If I find the link I will post it, if anyone else finds it on Mantis please post it.
JOD.
When I had my bad pin code scenes set up on my schlage levers, it would take 4 consecutive bad entries before the scene would fire. I know this for sure, as I regularly verified that the scene would activate - I had lights turn on and a ptz position called for the camera.
thanks much for the feedback, will test this next time im onsite
