I have spent the last couple days reading tons of info on here and am admittedly a bit confused. Mostly, its just hard to follow which products people are specifically talking about. It seems most of the discussion is regarding schlage deadbolts and problems with getting certain firmwares to work properly with vera systems. But also many of the topics regarding these things are a year or more old.
My front door lock broke 2 days before I was scheduled to travel. With pet sitters coming multiple times a day, there was just not time to get/install a lock and get keys to everyone. So I jumped on the FE599 starter kit. I have it set up (and on free trial) with the nexia bridge and it works great. I did not have a lot of time to research before I had to pull the trigger on the overnight amazon order, but I gathered enough to realize I would likely want to swap the nexia bridge for a VeraLite. Now its time to do that, but a bunch of reading here has me a bit confused.
So my question is for anyone that is using these devices:
Does the FE599 work well with the VeraLite?
Can I set it so I get an email with who opened the door when someone enters their code?
Will I still be able to, Remotely (via android app):
correctly see if the door is locked or unlocked?
open the door?
set up a temp code?
Is there anything else I need to know about missing/incorrect functions using the VeraLite over the Nexia bridge?
Info on my particular lock via the nexia UI…
Node 2 - Entry Control - SchlageLock::Lever
Node Type: 044003
Command Classes: [“85”, “73”, “72”, “98”]
Version: 0602402B25
