Schlage door lock out of range ???? Update nodes for repeater???
Hi all, thank you for the help in advance as i’m not pro at vera yet. My issue is I installed Schlage FE599 door lock. I have it linked up and work. How ever when i move it to the door where it goes it fails " sending z-wave command after 3 retries" and on and on till it fails and gives up “Error cannot send command to node”. I read you can put a AC switch near buy so improve the coverage. So i added dimmer switch WED500-2 Linear. Not sure if this is helping or not. Do i need to some how tell vera to update node mesh or something so it knows what should be acting as repeaters and what should be going directly back to vera without any node hops? I seen somewhere in the options a button about update nodes or something and not sure what this does.
thanks again for the help!
I’m running firmware 1.7.4001 on Vera Plus-US
Your Vera should do a nightly or near nightly “heal” which updates its nodes.
