Schlage Deadbolt Almost Working. Need Advice.
I had a lot of trouble getting a BE469NX to work correctly. After a lot of time I got it to work (well sort of). I found out that Schlage has updated the locks firmware. I called Schlage and they replaced the lock. The new lock setup quick and has worked without any problems. I would suggest a call to Schlage might help. They were very helpful when I called.
+1 on the lock firmware. I did not have any problems pairing the Schlage lock to my Vera3, with the Vera3 located in its permament spot. You want the lock to be on version 5.8.
This thread has a lot of information in it about the firmware issues:
http://forum.micasaverde.com/index.php/topic,13334.0.html
