Schlage Connect PIN Codes in Dashboard
I added a couple PINs from the lock interface. I went to the PIN code screen and checked the box to show PINs in the clear but they won’t show. Is there any way to edit the PIN names? I tried adding a new one from the dashboard with my name but it reverted to “Code 5” and the PIN code is blank.
Thanks,
Mike
Show in clear has to be selected before adding the pin codes
