I’ve been reading through these forum posts and I can’t seem to get a clear answer on this. I have a Schlage BE469 in a vacation rental. I want to provide each guest with their own pin, and schedule check-in and check-out dates that the pin will be valid. Can I do with with Vera Lite (or any other Vera hub)?
After you add a pin you can add restrictions, set to daily then set the start and end dates.
I am having problems adding restrictions. I get the “Failed to apply Restriction” message if I try to add a weekly or daily restriction to a Pin Code
