What I want: between 10pm and 7am, if motion sensor is tripped, it turns on a light for 2 minutes.
What I have: all of the above except the scheduled hours.
I can schedule to start at 10pm but how do I have it end at 7am every day?
VeraPlus, if that matters
Hello @norwestie,
You can add a time restriction to your scene so it only happens in the desired time interval. To do that, go to “Step 1: Select a trigger” when creating or editing the scene, click the clock icon next to the trigger (see the first image below), and then set up the time restriction (see the second image below):
Kind regards!
