Schedule trigger doesn't work
Hi all,
I’ve tried to make scene which is switching on Philio 06 relay every 10 minutes, and after 1 minutes switching off.
When I run it manually (pressed run from Scenes menu) it worked OK, but then when I was waiting for automatic switch on/off nothing happened.
Even when I’ve change schedule triggering to trigger every day at hh:mm:ss time, and this time came - nothing happened.
I have Vera Lite with UI7 with 1.7.690.
Does Schedule trigger work at all?
Hi
Mistery solved. When my Vera was connected to internet and got correct date and time, everything was working ok.
