On my new Vera Lite I created a scene to lock my new Yale Keyfree lock daily at a set time. No matter how many times I save it, when I go to edit the scene and look at the settings, the action is labeled as “unlock.”
If I test running the scene, it does lock the door as expected, so the problem is that the action label is incorrect. It always says unlock no matter if the real action is lock or unlock.
Is there a way to fix this?
