Schedule not working?
My first post…I have read the forum for weeks and weeks, a ton of good information. I recently had a problem where my schedules are not working.
I want to turn off my lights everyday at 22:00. But the last time it was run was 12/13???
You have a scene with a schedule and the schedule’s Enabled check box is checked? And, the schedule is set to “Day of week based” with every day of the week checked and Time set to “At a certain time of day” and the 22:00:00?
If the above is true, I would try deleting the schedule and recreating it. If the scene isn’t too complicated, I’d delete the whole scene and recreate it.
This should help, see the attached schedule below. Also, it looks like the schedule is working, but the last run is not.
The last run column is not updating.
So, the light is actually turning off, but the shown last run date is not matching the actual last run date?
What browser are you using? Have you cleared the cache and refreshed the browser?
I am always using the Vera Interface in a “Inkognito” / “in-private” / “private Tab” mode. No problems when using so. Using with normal Browser IE FF Chrome Opera w or w/o cache cookies delete never works properly.
