Schedule input off by 6 hours
Hello,
I’ve a schedule defined for one of my scenes, however PLEG appears to be out by 6 hours. All other time based events are working fine. I’ve had a quick search but couldn’t find any reference to a similar problem.
As you can see from below, the schedule is from 2100 to 0900, however in the Last On/Off columns, it states that it started at 1500 and finished at 0000. Maybe there is a problem with schedules that start on one day and finish on the next?
Schedules
Name On Type On Time On Days Random On Delay Off After Type Off Time Off Days Random Off Delay State Last On Last Off
LowLightSchedule Interval 21:00:00 None Interval 09:00:00 None false 2015-10-27 15:00:00.101 2015-10-28 00:00:00.101
Thank you for your help
Have you restarted your Vera?
You have interval schedules …
Every 21 hours it starts … (in this case at 15:00:00)
9 Hours after it starts it turns off. (in this case at 00:00:00 equivalently 24:00:00)
[quote=“RichardTSchaefer, post:3, topic:189413”]You have interval schedules …
9 Hours after it starts it turns off. (in this case at 00:00:00 equivalently 24:00:00)[/quote]
Ahhhh right I see. Is there a method of achieving what I want?
Think I’ve worked it out:
Schedules
LowLightSchedule	Weekly	21:00:00	1,2,3,4,5,6,7	None	Weekly	r	1,2,3,4,5,6,7	None	true	2015-10-28 12:00:00.101	2015-10-28 00:00:00.101
