Schedule for "Sunrise" or "Sunset" doesn't seem to fire
When I setup a schedule that uses “Sunrise” or “Sunset”, the event doesn’t fire. How does this work? Is it checking a website based on my location to determine this time?
Also is, it possible to setup an event for Sunrise +/- 30 minutes? I want some external lights to be dimmed when it’s really dark, bright at “magic hour”, and then off when it’s truly light out.
Thanks,
Luke
You must setup your Location and TimeZone in the Setup tab.
Great - thank you, set it and will test this AM.
Do you know what the definition of “Before Sunrise”, “After Sunrise”, etc. mean? 30 minute buffer?
Never mind, I see that it’s configurable. I’m all set.
