From what I can tell most dimmers return to their last level when activated again. This applies to Z-Wave and Insteon dimmers I have installed. At certain times of day, one level is generally preferred, while another level is generally preferred at other times (e.g., 100% from 7AM until 9PM; 20% from 9PM to 7AM). I am thinking about a way to schedule this.
What I have considered is setting a scene that turns a light on at a certain level at a certain time (e.g., 100% @ 7AM) and then turn it off as quickly as possible). Until the dimmer is adjusted, manually or otherwise, it will then resume to this level. Another scene can take care of the rest of the scheduling in my example, and I can then apply this to multiple dimmers.
This is not terribly graceful, however, and I don’t love the idea of lights (seemingly) randomly flashing around the house. From a WAF perspective, the amount of explanation for this is not worth the effort.
Is anyone aware of a scripting solution that can solve this without the lights being flashed?
I don’t know the answer to that, but surely there must be a way to send your dimmer a command to “set” its LoadLevelStatus a new “last known dim level”
Shouldn’t it be something similar to “configuring” the polling time of the dimmer? (ie.: for example, when you change the polling-time of the dimmer in the Settings tab and you press the [configure-now] button, doesn’t it send the value into the dimmer?)
So isn’t there something similar that can be done for the LoadLevelStatus of the dimmer to change its value to 100% for example so that the next time you press the top of the switch, it will light up all the way to the last-know-dim level (100%)???
Anyway if you do figure something out, let me know as I sure would like that too
It depends on your dimmer. There are two commands of interest SetOnEffect and SetOnEffectLevel that provide the functionality that you desire. Vera supports this functionality, but most dimmers do not support this command class.
Chances are high that the only way to accomplish what you desire is to set the device to the desired target level(SetLoadLevelTarget) and switch them off on second later.
Attempts to solve this with Vera’s native z-wave calls were not effective. A review of Leviton’s website suggested the function exists, but they never responded to a technical support request. In the interim, I have switched most lights over to Insteon and have found that there is a very graceful solution that does exactly what I want (two different methods in fact) in that technology.
Re Insteon, accessing the dimmer switches via software (e.g., the ISY controller), you can do either of two things:
Set a deault on level that is below 100%, with a second press going immediately to 100%. This is similar to the patented (and therefore missing elsewhere) double tap function that Lutron’s non-ZWave switches have, but is implemented in a different way. For example, there is no time limit for the second press, and further on presses alternate between the dimmed and full levels.
Use ISY Programs to modify the default on level of a dimmer switch based on any criteria available (including schedule), which is then written directly to the switch; this achieves exactly what was described in the original post. A single tap could go to 25% at one time of day and 75% at another time of day, for example. The lights would not be turned on to achieve this.
These functions must be accessed through software. The free Houselinc software would (I believe) allow you to manage the first method above, but I am not sure if it does the second.
