Scenes and Sunset
I am new to to the vera and have an initial question. I have some lights that I want to go on when it is dark and I would want to use the sunset command.
Do I create a scene and then use the schedule to set it on at sunset.
Then if I want to to go off 4 hours later so it is only on 4 hours and not all night, do I create another scene for it to turn off 4 hours after sunset? Or I guess I can do the off at a fixed time.
Question, do I do all this with one scene or do I need two scenes?
thanks,
Mike
You need a scene to turn light on at sunset and another to turn the lights off at the desired hour.
Unless, you put a delay in the ‘on’ scene switching off the lights.
Most would likely recommend the two scene approach.
