What’s up everyone, I have a question I have a Vera 3 and I want to turn a outlet on for two to three seconds then turn it off. I am triggering a relay to control my garage door opener. any help would be great
Eli
Eli
Why not look at the garage door plugin?
Do you need to do this via some code?
If you create a scene (under the Automation tab) you can build out that 3 second delay via the Advanced tab, by setting the interval you want before you turn (whatever it is you need to turn off) off .
