So i created scene widget on my home page, When I select the icon it runs the scene (good) but it auto opens the imperihome screen (bad). is there a setting or a way to have it run the scene but stay on my home page?
From the List view in the app, I scroll to the bottom section listed as ‘SCENES’. I then long press on one scene and then select the ‘Configuration’ option. Then, at the bottom of the list I select the ‘Add Shortcut’ option. Is this how you created your scene icon on your android home page?
When I click that shortcut it only displays a verification message that the scene is successfully executed but the app is not launched. That is not what you are experiencing?
EDIT: Ok I just noticed there are widgets you can add. I just added one and launched a scene and it had the same icon and operation as the method I described above. So in both cases it does not open the app. It just executes the scene.
