I’m looking for some idea on scene trigger… I mean, without having a wall keypad…
For example, I create a scene that run when I close the front door light between a time frame, to rerun a scene that prepare the house for the evening… this way, if I’m having some friends at home and they are leaving after the original scene, I can retrigger the scene myself…
But I would like to know if it’s possible to create some scene trigger using a kind of counter, for example, if I hit “OFF” 2 time in a row of a light switch, it can trigger scene…
I’m looking for some cool scene trigger idea you already have…
The following LUA code is what I use to detect multiple clicks on a scene button that occur within 10 seconds of each other. Scenes are sometimes slow to react, so I found 10 seconds to be necessary.
function ResetFRIndicator(stuff)
sFRIndicator = "0"
if (sFRIndicator == "1") then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" },21)
else
sFRIndicator = "1"
luup.call_timer("ResetFRIndicator", 1, "10", "", "")
What this scene does is turn on a second light if the scene is activated twice. (The scene itself takes care of the first light.)
If you do not have instant status … Vera will not see the switch has changed until it polls … Upto 10 minutes later … And then it can’t tell how many or if you cycled the switch since the last poll.
