I am using Vera lite with a schlage lock. I would like to create a scene that when anyone comes home the unlocking of the door would trigger a lamp to go on so we are not walking into a dark home. I have tried to implement this but I must be missing something. Any help would be appreciated.
I assume you only want the lamp to go on when a PIN is entered on the door, and not every time the door is unlocked (otherwise unlocked it from the inside would trigger the scene as well).
Once you try to run a scene based on more than 1 thing (Lock and NightTime in your case) than you have exceeded the capabilities of the UI5 user interface.
You have a couple of options:
[ul][li]Combination Switch plugin[/li]
[li]Program Logic Event Generator plugin[/li]
[li]Lua Code - With code you can do just about anything.[/li][/ul]
I listed these in the order of easy but limited, to hard but flexible.
