scene still running ?
i have some scenes doing things over time.
and sometime they do overlap.
so a simple check in luup would fix that
does anyone know how do i find out if another scene is still running ?
for a example.
my “back from away” scene does turn off the backyard light (away + night = backlight stays on)
my scene for “car return” (triggered by my car) turns on the driveway and garage light and turns off the garage light after 25 minutes
the “return scene” also turns off the Away switch, trigger to run the “back from away”
but i want the backyard light to stay on for some time to give me light while unpacking stuff.
so a simple check in “back from away” for “car return” is still running would prevent the lights from going off immideatly.
but how do i find out a scene is still running ? or a timer within a scene ?
A scene does not continue to run. A scene is simply a set of commands, such as turn this light on, this light off, set a timer to turn that light on after X minutes, and so forth. After the commands are sent out, the scene is finished.
So it is not meaningful to ask if a scene is still running. What you can check for is if the effects of the scene are still there (i.e. if a light is still lit).
well i also asked if its possible to check on a timer for a delayed run (since they have names it may be possible)
i can not check on the status of something thats not happen yet.
If you go to the Dashboard > overview, it has both Triggers and Schedule and the times they were either last executed or next scheduled
that would help already … so i can simply check if they had run within the timer ranges …
do you know how i can fetch this informations using Luup ?
See http://forum.micasaverde.com/index.php/topic,14570.msg110392.html#msg110392
