I’m not sure what happened with my Vera Plus. A couple of days ago I noticed some strange behavior that some of my scenes were no longer running properly. For example the scene that turns my garage lights on based upon a motion sensor partially worked; the light would come on but the delayed action to turn them off wouldn’t. The scene to close the garage doors wouldn’t run as well as some timed scenes for turning lights on and off.
When I’m looking at the dashboard and manually trying to run scenes, sometimes they will run but most times I get the “Scene Run Failed” error. I’m at a loss as to how to start debugging this issue. I’ve reset the controller, cycled power, and reloaded the z-wave engine and none of this cured the problem.
Any suggestions as to how I can go about debugging this?
