Scene "Run" button color
Why are some Scene “Run” buttons green and others not?
If you go to the active tab in the configuration of that scene you will see two options for “Scene is active” – when all devices in the scene are properly set or when any light light in the scene is turned off.
So, if you had a scene that set three different lights to 60%, and the first option listed above is selected, that button would be green (active) anytime those lights are set at 60%, even if they were set that way outside of running that scene.
Wow - that is cool - I have seen the different colors, but never knew that they meant anything. Great to know. Thanks.
