Scene Help
How do you put a delay of a notification on a switch after it’s turned on or off?
Can anyone help me with this?
When you say “notification” I’m assuming you mean email or txt? I dont believe you can add a delay to emails or txts. However, you could work around that by creating another scene. Have the switch you are monitoring be the Event, set your delay then in Commands select another device to turn on or off and then send you the notfication.
JOD.
