Scene help with Elk and Schlage door lock
Hi All I was hoping to get/find some assistance with setting up a scene involving an ELK Alarm and schlage door lock.
What I am trying to accomplish is an Alarm On Scene (when I leave the house and the Schlage is locked the Elk alarm is set to Armed) and an Alarm Off scene (when I return home and unlock the Schlage lock the ELK disarms and the foyer light turns on)
The problem I am running into is that the lock button (or in this case the Schlage button) does not trigger an event/scene so I have to use ?when a pin code is entered?. This causes a conflict between the two scenes as it runs both right after each other (i.e alarm on scene runs and then the alarm off scene runs.
Is there a work around or another trigger that I should be using for either scene to get this to work?
Any help/advice would be great.
I am using a VERA 2 on UI5
THX
Chris
So no one has any pointers on this?
You are using the right trigger for alarm off (when a pin is entered), but unfortunately there is no way to know if the lock was locked from the outside vs the inside. I had a similar desire to use that trigger and it just doesn’t exist.
Sent from my Nexus 7 using Tapatalk
You can in fact tell whether the lock was transitioned mechanically (from the inside) or electronically (outside). I posted the Z-wave exposed parameters for the BE469s previously here: http://forum.micasaverde.com/index.php/topic,22382.msg150033.html#msg150033
Hope this helps.
Thanks @TC1?! I didn’t know that was possible!
OK… I think I’m being draft. How do I set those params and once I do, are there new triggers?
